PShetty
7 years agoTri-state Conduit bridge signals are not matching with the generic tri-state controller
Hi, we are using tri-state conduit component to interface to the FIDO/Ethernet switch in Arria 10 SoC. But Generic ti-state controller master port-tcm signals and tri-state conduit bridge slave port...
Nathan_R_Intel
Contributor
7 years agoHie,
I don't have details on your full QSYS design, hence I believe you have identified the problem which is the conduit component used does not have an interface that matches the Generic Tristate Controller. If your Quartus version don't have a tri-state conduit component that matches, then you will need to build the bridge yourself. Do let me know you Quartus version, so I can check and advice accordingly.
Nathan
