16 years agoTRDB-D5M with Cyclone 3 Development board
Hello My name is Hardik Shah, I am using Terasic camera(with HSMC->40 pin converter) with Cyclone 3 board and trying to display the images taken by the camera on the HSMC Multimedia display. ...
14 years agoHi Hardik,
Thanks for your quick response. I got it clear now. When you say to calculate the no. of pixels, do you mean to configure the Sensor Row and Column Size registers (0x03 and 0x04)? I now have a row size set as 2047 and column as 2559. I also use row and column skipping to skip every alternate row and column and also binning set as 1 ( Registers 0x023 and 0x024). Now from one the tables in the TRDB-D5M datasheet, I understand that such a configuration would result in a resolution of 1280x1024 and a Frame rate of 40.1 Is my understanding right on deriving my Frame Rate? :confused: Kindly comment. Best Regards, BVP
