aamodini
2 years agoTransfer Data from Nios II to FPGA using Avalon-ST
I am trying to transfer a chunk of data from Nios II to the FPGA fabric using the Avalon Streaming interface, and am facing a couple of challenges in implementing the same. 1. I'm unable...
aamodini
2 years ago1. I see two warnings on the Platform Designer that say almost_full and almost_empty signals must be connected to an Avalon-ST sink (as seen in the first image attached). Hence I was just wondering if they should be connected.
2. Does it mean I would just write to the FIFO just as I would in the case of a simple array/buffer?
Oh I wasn't aware NIOS doesn't support streaming. Is there a documentation that says so?
Thanks for the inputs!
