14 years agoTR4 (or DE4) PCIe Image Processing demo (64-bit)
Hi, Has anyone been successful in running the TR4 (or even DE4) PCIe Image Processing demo? I have installed the drivers and used the right DLLs. The Fundamental demo works fine for me, i...
14 years ago --- Quote Start --- Thanks for the reply. In fact, I have sent emails to Terasic prior to posting here. Their advice was to download the latest version of the CD, which I have, and the problem persists. --- Quote End --- Ok. --- Quote Start --- I am trying to test the PCIE0 Image Processing Demo. As mentioned earlier, uploading the image from FPGA to PC gives me a garbled image (image data not aligned properly). Not sure if the problem lies upstream or downstream. I am using Windows 7 64-bit. --- Quote End --- I have a Windows 7 64-bit setup as well. Walk me through what you do to see this problem, and I'll try it on the board I have. For example 1) Which version of the demo CD? * I installed DE4_v.1.2.1_SystemCD 2) What is the PCIE0 Image Processing Demo? * demonstrations\DE4_530\PCIe_ImageProcess? * or are you using the 230 board? 3) What did you do to try and run the design? * just follow the instructions in usermanual\DE4 User Manual.pdf? You can email me directly if you prefer (my forum name is my email address). Cheers, Dave
