14 years agotPad, DE2-115: ControlPanel will not connect ....
I got my tPad dev kit today and now I'm trying to enter this new field of technology. * I'm working under Windows 7/64 Bit. * As other users I had problems with the USB Blaster drivers, but I...
14 years agoYes, I did this - but the answer is:
"We have tested on running the control panel by using different Quartus II version, and the tests all succeeded." Other solutions I've found in the Internet (after doing lots of search in this area): copy all the stuff to the bin directory of Quartus and manually copy the sof file to the board. Then the control panel indeed works as expected - this solution was also mentioned by the support.
