14 years agotPad, DE2-115: ControlPanel will not connect ....
I got my tPad dev kit today and now I'm trying to enter this new field of technology. * I'm working under Windows 7/64 Bit. * As other users I had problems with the USB Blaster drivers, but I...
14 years agoOk, I have installed a new fresh Windows 7/32 bits and its always the same - on both installations: 32bit or 64bit.
-> The 32bit ControlPanel (from the DE2-115 DVD) has missing dll's. I had to copy all files of the ControlPanel to the Quartus directory to have it start at least - but even then I get the error mentioned below. -> ControlPanel always tells me: "Please make sure that Quartus is installed" -> then I tried the tpad demonstrations (by executing batch files) and most of the stuff is not working. The only demonstration, which works is tPad_Camera. All other demos are aborting - mostly with the same error: command not known: nios2-donload and nios2-terminal. These errors happened in a GCC3 Altera Nios2 Command Shell, Versin 11.1sp1, Built Thu Nov 4 .... When I start the Nios Comand Shell from the Windows menu I get a different bash (GCC4 named) and there the commands nios2-download and nios2-terminal are known.
