MaheshRV's avatar
MaheshRV
5 years ago
Tool Crashing when generating bitfile for FPGA OPENCL code with Profile switch enabled
We are trying to generate bitfile for FPGA with our openCL code with Profile switch enabled.
The command used is "aoc -v device/simram.cl -o bin/simram.aocx -report - profile" .
Instead of generating the bitfile, the tool crashes everytime.
Kindly Suggest if we are missing anything here. Need Help here in generating Bitfile with Profile switch enabled.
  • aikeu's avatar
    aikeu
    Hi MaheshRV,
    Do you still require help for this issue?
    Can try the below:
    • Run the "- profile" as "-profile"
    • Compile whitout a the "-profile"
    Aik Eu
    • MaheshRV's avatar
      MaheshRV
      Yes, we still need help here as we are still facing the same issue.
      Regarding "Run the "- profile" as "-profile" " , yes we had already tried with "-profile" the space in the query got added by mistake.
      Regarding "Compile whitout a the "-profile" " , yes, we have compiled without the "-profile" itself.
      Even after this, we are still seeing the issue.
      Further to add, what we observe is-
      We are able to run -profile with less (PE = 32, 64) configuration but when we are increasing our configuration (PE = 128/256) the resources utilized are exceeding the FPGA size.
      Is there any way to optimize the profile logic so that we can fit in the given FPGA. Using Stratix 10MX where 80% is utilized by our code (with maximum config).
      • aikeu's avatar
        aikeu
        Hi MaheshRV,
        May I know the your openCL version?
        Other than that, where do you specify your PE configuration value?
        Aik Eu
  • aikeu's avatar
    aikeu
    Hi MaheshRV,
    Any recent follow up regarding this?
    Aik Eu
  • aikeu's avatar
    aikeu
    Hi MaheshRV,
    We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    Aik Eu
