TOF sensor with nios......How?
I need to use a TOF sensor using I2C to comunicate with nios. I used Intel I2C IP but not working. Please help.
- Ahmed_H_Intel1
Hi Mark,
Which TOF sensor you are using? is it an I2C sensor?
- MLash2
I am using vl53l0x which is an I2C sensor. it is working fine with the ARDUINO. please help to teach me how to use it with the FPGA.
- Ahmed_H_Intel1
You can use the I2C Intel IP to communicate with the I2C sensor.
I encourage you to see the following Example:
https://fpgacloud.intel.com/devstore/platform/15.1.0/Standard/usb20-bridge-usb-to-uarti2cadc-interface/
or to use Opencores IP as used here:
https://fpgacloud.intel.com/devstore/platform/16.1.0/Standard/i2c-opencores/
https://opencores.org/projects/i2c?do=projects&download=i2c
- MLash2
Thanks a lot @AhmedH_Intel
I think this help to start my business.
- MLash2
I see that I can use the DMA with the sensor, correct?
- Ahmed_H_Intel1
Yes, you can use the DMA to stream the sensor data for example or to update a memory with the sensor data.
- MLash2
Thanks a lot, I will check the DMA.
- Ahmed_H_Intel1
You are welcome.
