Mingyuexin
7 years agoTiming violation when use Triple speed Ethernet IP
Hi, In my design, I use Cyclone V SoC and I need 4 ethernet channels, so I have to use Triple Speed Ethernet IP the extra channels HPS can not provide. I referred to the example design (Niosii_e...
SengKok_L_Intel
7 years agoFor the TX, you can refer to my previous suggestion. For RX, you can try to add following setting in the .qsf file.
set_instance_assignment -name GLOBAL_SIGNAL OFF -to fpga_enet2_rx_clk
