Timing violation when use Triple speed Ethernet IP
- Mingyuexin7 years ago
Thank you very much for the quick response. I will try your suggestions and see.
Best wishes
Jasmine
Hi again,
I change the constraint for tx_clk*and enet_gtx_clk_* according to your suggestions, though I need to adjust it slightly to make it apply my case because the input clock for my pll is 50 MHz instead of 125 Hz.
I had a look at AN647 and the example design for Cyclone V GX.
It looks like the constraint set in the design is center-aligned for tx channel, but the tx clock does not have phase shift at all. In the design, it's actually edge-aligned for tx channel. So I'm very confused here.
Other than that, the setting for rx channels is different from AN477 also.
Until now, the example I mentioned (Niosii_ethernet_standard_3c120_rgmii.zip), the example described in AN647 and AN477 (and AN433) have conflictions, and I'm very confused now.
What can I do to improve the timing violation? What is the next step I can try?
Best wishes
Jasmine
