fxu001
7 years agotiming in I/O pads
Hello, Currently, I passed all setup, hold, recovery and removal timing within the FPGA with constraint all paths and I/Os, but my I/O through GPIO portion did not passed the timing. Do you have any...
KhaiChein_Y_Intel
7 years agoHi Fred,
If you open the Pin Planner (Assignments > Pin Planner), you will see the pins for each bank are colored differently. You may find the region that you want and select the pin, the pin number will appear under pin properties.
YY
fxu001
7 years agoOkay, I give you a little bit simple question. How to find out ALL GPIO location in X-Y coordination?
