Timing Constraint on SoC HPS Memory
Hi Johnson,
Firstly, may I know which Quartus version and SoC device are you currently working on?
Is it possible for you to share the message that you are seeing or screenshot? Which ever is easy for you, so that I can check what type of message is to be ignored.
Yes, timing constraints are fixed for both dedicated HPS I/Os for Cyclone V SoC and Arria 10 SoC you do not need to define it.
You may refer below for more information regarding the timing constraints on our SoC devices (refer Table 7 on both links )
Cyclone V SoC:
https://www.intel.com/content/www/us/en/programmable/documentation/doq1481305867183.html#qpb1481303809420
Arria 10 SoC:
https://www.intel.com/content/www/us/en/programmable/documentation/pde1458159073865.html#pde1458163562367
Thank you for getting back!
I am using Quartus 16.0.2 and the device is 5CSXFC2C6U23C8.
Below are Setup and hold time violation message.
Thank you!
BRs,
Johnson
