CThaw
7 years agoThis is important case found IC Intel/Altera Stratix® III Devices Failure [MFG PN: EP3SL70F780C4NAB] Failure during ICT [In-Circuit Test] under IBM BU. The failure symptom is FPGA Power +3.3VE Load to GND.
To immediate action and validate root cause of Altera Corporation's Component Failure. We had submitted case service requested via Intel Premier Support (IPS) Web Portal under Case 00423526 as below....
CThaw
7 years agoHello Wani,
Thank you for your always support.
Per internally discussed with Celestica Product Engineering Team base on analysis result. Please be archive these units at Intel Analysis Site during this time frame until further notice.
In case have any more additional recommend need to indicate specifically perform by Intel FPGA Support Team. Will back revert back to you in shortly.
- Zawani_M_Intel7 years ago
Hello Chaiyuth,
We will archive the units as requested until further notice. You can contact us anytime for any technical issue you have.
Thanks!
-Wani-
