CThaw
7 years agoThis is important case found IC Intel/Altera Stratix® III Devices Failure [MFG PN: EP3SL70F780C4NAB] Failure during ICT [In-Circuit Test] under IBM BU. The failure symptom is FPGA Power +3.3VE Load to GND.
To immediate action and validate root cause of Altera Corporation's Component Failure. We had submitted case service requested via Intel Premier Support (IPS) Web Portal under Case 00423526 as below....
Zawani_M_Intel
7 years agoHI Chaiyuth,
I believed you have received your ERMA report in our private message, I will close this case at this moment. If you have any concern on the report, you can continue to use our private message as usual.
Thanks!
-Wani-
