CThaw
7 years agoThis is important case found IC Intel/Altera Stratix® III Devices Failure [MFG PN: EP3SL70F780C4NAB] Failure during ICT [In-Circuit Test] under IBM BU. The failure symptom is FPGA Power +3.3VE Load to GND.
To immediate action and validate root cause of Altera Corporation's Component Failure. We had submitted case service requested via Intel Premier Support (IPS) Web Portal under Case 00423526 as below....
CThaw
7 years agoHello Wani,
Some progress update, We are expediting shipment process to drop return affect Stratix® III Devices Failure return back to Intel Microelectronics (M) Sdn Bhd - Malaysia perform failure analysis --> Forum#04117084 for Return Authorization Number.
The shipment tracking will provide back to you in shortly. Please stay tune...
