the tx_serial_clock and tx_load_enable signal of one exteral can not drive the lvds_tx in different BANK of Arria V?
Hello Lambert,
No problem , I re-created the issue you were seeing. Here is my thought on the same .
i) I am able to FIT differnet bank in the same row (i.e 3A ,4A ,4B,4C & 4D) with PLL.
ii) Quartus wont be able to route PLL between Bank 3A to 7A. from the Archteuture of Arria V A3 device it is clear that it is not possible directly.
One idea ,
We can try to use the PLL cascade and see you able route from 3A bank to 7A . I didn tried as of now .
Attavhed file for your reference for differnet bank in bottom LVDS channel.
Thank you ,
Sree
Hi Sree,
Thanks for your help, I have one problem that if I use the PLL cascade method to provide clock for lvds output locating in 3A and 7A , that means I will need two PLL output clk to drive different lvds output , if so, can I get the better phase relationship between the lvds output locating in 3A bank and the lvds output locating in 7A bank? Because I design this project for 16-bit DAC chip, so the lvds output needs good phase relationgship between each other.
Lambert
