Ravishankar's avatar
Ravishankar
6 years ago
The fpgainfo phy showing a port is flapping state
fpgainfo phy | grep -e "^PCIe" -e "^Port"
PCIe s:b:d.f : 0000:8a:00.0
Ports Num : 01
Port0 25G : Up
Port1 25G : Down <<<<<<<<<<<<<<<<<<<<<<<<<<<<
PCIe s:b:d.f : 0000:1c:00.0
Ports Num : 01
Port0 25G : Up
Port1 25G : Up
Ports Num : 01
Port0 25G : Up
Port1 25G : Up
Ports Num : 01
Port0 25G : Up
Port1 25G : Up
  • SengKok_L_Intel's avatar
    SengKok_L_Intel
    In order to better assist you, would you please let us know which PAC card that you are using? Is this N3000 or D5005?
    Besides, what type of server you are using for this PAC card? How many PAC cards in that server?
    Regards -SK
  • Ravishankar's avatar
    Ravishankar
    Thi is N3000 PAC Card. We are using Quanta server.
    There are two PAC card in this server.
    Ravishankar
    Please find the detailed FPGAINFO output-
    FPGA port mapping
    [root@<Compute_Name> ~]# fpgainfo phy | grep -e "^PCIe" -e "^Port"
    Ports Num : 01
    Port0 25G : Up << vc_sriov1
    Port1 25G : Up << vc_sriov3
    Ports Num : 01
    Port0 25G : Up << vc_sriov0
    Port1 25G : Down << vc_sriov2
    Check FPGA ports status with "fpgainfo phy" command.
    Board Management Controller, MAX10 NIOS FW version D.1.0.12
    Board Management Controller, MAX10 Build version D.1.0.12
    //****** PHY ******//
    Object Id : 0xEE00001
    Device Id : 0x0b30
    Numa Node : 1
    Ports Num : 01
    Bitstream Id : 0x2230120056D577
    Bitstream Version : 0.2.2
    Pr Interface Id : cf9b1c50-37c9-45e9-8030-f921b17d2b3a
    //****** PHY GROUP 0 ******//
    Direction : Line side
    Speed : 25 Gbps
    Number of PHYs : 2
    //****** PHY GROUP 1 ******//
    Direction : Fortville side
    Speed : 40 Gbps
    Number of PHYs : 2
    //****** PKVL ******//
    Port0 25G : Up
    Port1 25G : Down
    Parkvale A Version : 101c.1064
    Parkvale B Version : 101c.1064
    Object Id : 0xEE00000
    Device Id : 0x0b30
    Numa Node : 0
    Ports Num : 01
    Speed : 25 Gbps
    Number of PHYs : 2
    Speed : 40 Gbps
    Number of PHYs : 2
    Port0 25G : Up
    Port1 25G : Up
  • JonWay_altera's avatar
    JonWay_altera
    Hi @Ravishankar​
    Does this happen to SRIOV use case only?
    Could you explain the steps you took to replicate the issue?
    Ravishankar
    Yes this happends to only SRIOV port on the FPGA card. This is seen randomly in the Server having this FPGA card.
    What are other logs that we can see to get more details of this issue?
    JonWay_altera
    Hi @Ravishankar​
    Sorry for the delayed response. May I know if this issue has been resolved?
    If not, would you send me the steps to reproduce the issue.
