The fpgainfo phy showing a port is flapping state
Please find the detailed FPGAINFO output-
FPGA port mapping
[root@<Compute_Name> ~]# fpgainfo phy | grep -e "^PCIe" -e "^Port"
PCIe s:b:d.f : 0000:8a:00.0
Ports Num : 01
Port0 25G : Up << vc_sriov1
Port1 25G : Up << vc_sriov3
PCIe s:b:d.f : 0000:1c:00.0
Ports Num : 01
Port0 25G : Up << vc_sriov0
Port1 25G : Down << vc_sriov2
Check FPGA ports status with "fpgainfo phy" command.
Board Management Controller, MAX10 NIOS FW version D.1.0.12
Board Management Controller, MAX10 Build version D.1.0.12
//****** PHY ******//
Object Id : 0xEE00001
Device Id : 0x0b30
Numa Node : 1
Ports Num : 01
Bitstream Id : 0x2230120056D577
Bitstream Version : 0.2.2
Pr Interface Id : cf9b1c50-37c9-45e9-8030-f921b17d2b3a
//****** PHY GROUP 0 ******//
Direction : Line side
Speed : 25 Gbps
Number of PHYs : 2
//****** PHY GROUP 1 ******//
Direction : Fortville side
Speed : 40 Gbps
Number of PHYs : 2
//****** PKVL ******//
Port0 25G : Up
Port1 25G : Down
Parkvale A Version : 101c.1064
Parkvale B Version : 101c.1064
Object Id : 0xEE00000
Device Id : 0x0b30
Numa Node : 0
Ports Num : 01
Speed : 25 Gbps
Number of PHYs : 2
Speed : 40 Gbps
Number of PHYs : 2
Port0 25G : Up
Port1 25G : Up
