Humusk
7 years agoThe Ethernet ports of MAX 10 Development Kit suddenly stopped working.
The Ethernet ports of the boards no longer work. In the past I had a lot of problems to set up the ports as they were not working neither. After some time I discovered that I needed to press the rese...
Deshi_Intel
7 years agoHi,
May I know did you face the issue with your own design or using Intel FPGA TSE IP reference design ?
Can you try with below TSE reference design ?
https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/max-10-single-port-triple-speed-ethernet-and-on-board-phy-chip-design-example/
This should help to isolate whether the issue is with the board, RJ45 connector, Ethernet cable or Quartus design issue.
dlim
