amara5
7 years agoThe command aoc device/boardtest.cl --sw-dimm-partition -o bin/boardtest.aocx generates the message: Could not acquire a valid license for the Altera SDK for OpenCL and parser error details. Is it possible to get a trial license?
HRZ
7 years ago@KhaiY_Intel But obviously he cannot do that since the last BSP Terasic ever released for that board is only compatible with Quartus v16.0, which requires an OpenCL license, and using the old BSP with newer versions of Quartus does not work as is obvious from his compilation log posted above.
@amara5 I am afraid you have no choice to obtain an OpenCL license if you want to use OpenCL on your board. Contact Terasic and see if they are willing to provide you with an OpenCL license since, as mentioned by others, an OpenCL license is not required anymore in the newer versions of Quartus but you are forced to use an old version which does require such license since Terasic has not updated their BSP for your board (and probably never will).
