10 years agoTerasic TR4-230 Development Board Flash Programming Problem
Hi all, I have recently purchased Terasic TR4-230 Development kit and facing a problem with the CFI (common flash interface) flash programming using the PFL (Parallel Flash Interface) IP core....
10 years agoThank you Galfonz for you reply.
For programming the Flash, I feel NIOS is not required. I' got the solution after a bit of struggle and I could able to program the flash by putting the PFL ip in CPLD and upgrading the Quartus 14.0 to Quartus 15.1 s/w. There is a bug in 14.0 which is giving flash programing error with PFL IP core, which I found out through search. Regards Srikanth
