RLedu
6 years agoTerasic System on Modules (TSOM) Board - Cannot boot linux while programming FPGA
Hello, I have been working for a project on DE0-Nano SoC (Cyclone V) with hps-fpga programming : roughly to drive gpio's (fpga side) directly from a C program executed in linux. Following the manual...
EBERLAZARE_I_Intel
6 years agoHi,
I am unsure entirely, but you may need to check the MSEL, BSEL and CSEL pins respectively to your design.
If that is not the issue, you may want to try booting using our prebuilt image instead, then to get the board booting first time, then you may get used to the procedure on what is actually missing from the steps you did previously:
You can refer to the below link for reference to guide you:
https://rocketboards.org/foswiki/Documentation/GSRDBootLinuxSd
Also for more interesting topics such as compiling GHRD or preloader etc, there more below, you can select your devices and Quartus version available then the topics your interested in
https://rocketboards.org/foswiki/Main/GettingStarted
