11 years agoTerasic DE2: Lot of jitter with default SOF, SRAM timing problems, related?
I don't know if anyone could help me with the following issue: when I load up the default SOF (blue background, ALTERA-logo etc) to my DE2 board, I have a _huge_ amount of jitter on the screen. I mea...
11 years ago --- Quote Start --- This is the original DE2 with EP2C35. I did take a measure at voltages and they seem to be ok, although I can't do any real measurements due to lack of proper scope. What I also now tested was that I changed the VGA PLL to use the 27MHz oscillator as source. I still have jitter, although less than before. So the problem might be elsewhere (some signal termination?). I really hope the FPGA is not faulty. --- Quote End --- I'm not sure that 27MHz is the correct frequency for VGA. For example, take a look at http://en.wikipedia.org/wiki/crystal_oscillator_frequencies Scroll down to 27.0MHz and you'll see that it is the reference frequency for NTSC/PAL, but scroll down a little further and you'll see that 28.322MHz is a VGA frequency. Just because Terasic put a 27MHz clock on the board means it is "correct" for all applications. It may be that they expect you to use a PLL to configure the VGA interface. You might want to do a little searching to see what other VGA examples exist for this board. Hamblen has a book and examples ... http://users.ece.gatech.edu/~hamblen/de2/ Cheers, Dave
