18 years agoTerasic DE2-70 Board
Hi, I'm planning on ordering an altera DE2-70 board from terasic and i was wondering if anyone could tell me if their general impression of the board. My university uses the DE2 for all of its ...
18 years agoBoth of you, this attitude is unlikely to get you very far.
Still: download this simple zip with three files: http://thorn.ws/de2-70-flash-leds.zip This is about the simplest example of a standalone design (it's just flipping bits). I included the Verilog code below (the indentation is mangled by the altera forum), but you'll need the (trivial) project file and the assignment file from the above zip file. All I did was to take the default example and boil it down. It really isn't Terasic's job to provide tutorials. That they did anyway to quite impressive. Regards Tommy -- (but now I want a DE3!) module test2(input iCLK_50, input [17:0] iSW, output reg [6:0] oHEX0_D, // Seven Segment Digit 0 output reg oHEX0_DP, // Seven Segment Digit 0 decimal point output reg [6:0] oHEX1_D, // Seven Segment Digit 1 output reg oHEX1_DP, // Seven Segment Digit 1 decimal point output reg [6:0] oHEX2_D, // Seven Segment Digit 2 output reg oHEX2_DP, // Seven Segment Digit 2 decimal point output reg [6:0] oHEX3_D, // Seven Segment Digit 3 output reg oHEX3_DP, // Seven Segment Digit 3 decimal point output reg [6:0] oHEX4_D, // Seven Segment Digit 4 output reg oHEX4_DP, // Seven Segment Digit 4 decimal point output reg [6:0] oHEX5_D, // Seven Segment Digit 5 output reg oHEX5_DP, // Seven Segment Digit 5 decimal point output reg [6:0] oHEX6_D, // Seven Segment Digit 6 output reg oHEX6_DP, // Seven Segment Digit 6 decimal point output reg [6:0] oHEX7_D, // Seven Segment Digit 7 output reg oHEX7_DP, // Seven Segment Digit 7 decimal point output [17:0] oLEDR); assign oLEDR = 'h55 ^ iSW; always @(posedge iCLK_50) {oHEX5_D,oHEX4_D,oHEX3_D,oHEX2_D,oHEX1_D,oHEX0_D} <= {oHEX5_D,oHEX4_D,oHEX3_D,oHEX2_D,oHEX1_D,oHEX0_D} + 1; endmodule
