14 years agoTerasic DE2-115 Flash programming
Good morning, Have been developing FPGA and NIOS-based SW for DE2-115 using USB blaster to load SOF and elf files for debugging. Now want to permanently program FPGA and FLASH. Have been ...
14 years agoThe programmer actually creates a SREC FLASHable file that includes a bootloader. When you apply power, the bootloader copies your application from FLASH to volatile memory. When you run the programmer and select the BSP/SOPC file, you should see a reference to the bootloader in the elftoflash command line....
Basically, it's all taken care of by the tools..... ME
