14 years agoTerasic DE2-115 Flash programming
Good morning, Have been developing FPGA and NIOS-based SW for DE2-115 using USB blaster to load SOF and elf files for debugging. Now want to permanently program FPGA and FLASH. Have been ...
14 years agoHave read other posts. I do see quite a bit of discussion on Offsets. If I read the FLASH programmer guide it indicates that the ELF file should not specify an offset.
Am not specifying a SOF file in the NIOS Flash programmer as I loaded the POF through Quartus programmer. The board contains an EPSC for the FPGA as well as a CFI FLASH for the NIOS Application.
