9 years agoTerasic DE10-nano Question - Why does DE0 rbf work on it?
We recently obtained a Terasic DE10-nano development board and installed their Linux Console (kernel 4.5) image on its SD Card, the board booted up as expected. We noticed we could put our old DE0 ra...
9 years ago --- Quote Start --- We put the DE10 SD back into the DE10 board and powered up - the .rbf file loads, CONF_D turns on and the embedded executable runs properly under the Linux system. This embedded executable needs two verilog cores we wrote and configured under Qsys to run properly. I understand the HPS systems are similar but the FPGA configuration also? Maybe it has something to do with Qsys compatibility? Thanks you for your attention. --- Quote End --- That's quite weird as it should not be loaded successfully. We've also tried to put the rbf file into the DE10-nano in our side, but it turned out failed. Is it possible to provide us with the rbf for our testing?
