Synthesis time of different FPGA types
To answer your questions:
- No, synthesis time is design dependent. If you have a large design using a large amount of resources then it will take a long time to synthesize your design.
- No, again synthesis time is design dependent. However, different FPGA offer different performance levels: intel.com/content/dam/www/programmable/us/en/pdfs/literature/sg/product-catalog.pdf
- So far we don't see any synthesis problems that depend on PC hardware or OS. Just make sure your system and software meet the right requirements: https://fpgasoftware.intel.com/requirements/21.3/
To add to that, sometimes we have problems that causes long synthesis/compilation time and these are mostly caused by the Quartus software, not the FPGA itself. You may refer to our KDB to see if it's a known error: https://www.intel.com/content/www/us/en/support/programmable/kdb-filter.html#q=long%20compilation%20&sort=%40articlepublisheddate%20descending
You may also refer to this document on how to speed up synthesis/compilation time: https://www.intel.la/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-compiler.pdf
Nurina
- Nurina4 years ago
We did not receive any response to the previous question/reply/answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
