Stratix10 SX Soc Development Kit boot failed randomly
Just to confirm, following the guide here still leads to the following error?:
https://rocketboards.org/foswiki/Documentation/S10GSRDBootLinuxFromSDCard180
May I know how many board is affected?
When you mentioned "and got an extra HPS HILO DDR Card this week.
We plug the DDR Card onto the evaluation board."
Are you describing that you are replacing/change the dev kit's default/original DDR? If so, may I know the part number you are using?
Thanks for your reply. @EberL_Intel
I only have one Stratix 10 SX dev board. I follow the guide and still get the error.
The sof I try to boot with JTAG is https://releases.rocketboards.org/release/2019.04/gsrd/s10_gsrd/ghrd_1sx280lu2f50e2vg_hps.sof and the same problem happens.
There is no original HPS HILO DDR4 card in our kit box when it comes to us.
I believe the reason is https://www.intel.com/content/dam/altera-www/global/en_US/support/boards-kits/stratix10/dcl-ddr4-hilo-notice.pdf .
So we got the separated HPS HILO DDR4 card with our local vendor's help and installed it on the mainboard.
The HPS HILO DDR4 card is "MEM MODULE HILDCDDR44GA DDR4 HiLo Daughter Card". The label on the card is "ALTERA DDR4 X72 DAUGHTER CARD".
We are trying to contact the local vendor for another HPS HILO DDR4 card. But it needs weeks to get a new one.
At the same time, we run Board Test System.
We see BTS shows many "Detected Errors" in DDR tab.
Besides, the results of "FMCA", "FMCB".... are not all exactly the same as the user guide (Intel Stratix 10 SX soc Development Kit User Guide).
For example, in the FMCB tab, it shows "PLL lock: Partially Locked" in our BTS test.
Our BTS test is following the instructions in "5. Board Test System ".
One of our question is the result of BTS can be relied on or not.
If the BTS is correct, does it mean we should change the dev kit with a pre-installed HPS HiLo DDR4 card from our local vendor?
