Stratix10 SX Soc Development Kit boot failed randomly
Thank you @EberL_Intel ! I'm using Quartus Prime Design Software Version 18.1.0 Build 222 09/21/2018 SJ Pro Edition.
I tried two version 2019.04 and 2018.10
https://releases.rocketboards.org/release/2019.04/gsrd/s10_gsrd/ghrd_1sx280lu2f50e2vg_hps.jic.gz
https://releases.rocketboards.org/release/2018.10/gsrd/s10_gsrd/ghrd_1sx280lu2f50e2vg_hps.jic
both have the same issue.
Also tried BTS bts_ddr4.sof, and got lots "Detected Errors" ( 521 million erros in 27 seconds), do you know if that's normal?
The BTS i am using is from https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/stratix-10-soc-development-kit.html "L-Tile Production"
Josh
Hi Josh,
I recommend that you try to program the .sof using JTAG config scheme, rather than programming the jic via flash.(programming .sof via JTAG config section)
https://rocketboards.org/foswiki/Documentation/S10GSRDBootLinuxFromSDCard180
Based on my experience, the bts_ddr4.sof is not the .sof file that is use to program.
Regards.
