13 years agoStratix V Transceiver Reconfiguration issues
Hi, I'm using a dev kit, the transceiver signal integrity developement kit with a Stratix V Gx. I have implemented an IP with Qsys of a transceiver in 10G BASE-R configuration with an Transceiv...
13 years agoExactly.
I use only a Stratix V, I cannot tell if with Arria V we could have the same issue. I mention before that the devices I have installed (for Quartus v12.1) are only for Stratix V and Arria V (it's a package), but I'm not using an Arria V. But yesterday I've changed the parameter to another one (value just under the default one) and the Transceiver worked. When I put the value I wanted, the Transceiver stopped working and I had to reprogram the whole design (setting all the defaults values and resetting). Had you already have this problem ?
