13 years agoStratix V Transceiver Reconfiguration issues
Hi, I'm using a dev kit, the transceiver signal integrity developement kit with a Stratix V Gx. I have implemented an IP with Qsys of a transceiver in 10G BASE-R configuration with an Transceiv...
13 years agoHi,
I'm using Quartus v12.1 with the devices associated to Stratix V and Arria V. I'm not using Nios 2 but I will, I'm writing command with system console in first case. I have used the toolkit to reach best parameters. But now, with my design, the transceiver stop working when I'm changing pre-emphasis second post-tap. Thank you for your interest
