13 years agoStratix V Transceiver Reconfiguration issues
Hi, I'm using a dev kit, the transceiver signal integrity developement kit with a Stratix V Gx. I have implemented an IP with Qsys of a transceiver in 10G BASE-R configuration with an Transceiv...
13 years agoWhich ACDS release are you using? Are your design using Nios 2 to control reconfig controller? Are you using toolkit to test the analog reconfig?
