13 years agoStratix V Kit-Programming SiLabs 5338 w/ FPGA
I have the Stratix V GX development kit, that has two SiLabs 5338 devices that can be programmed using the Clock Control GUI and the JTAG programmer. What I want to be able to do is program t...
13 years agoDave,
The I2C is not connected to the FPGA. Only through the CPLD. A google search for MNL-01063-1.3 will result in the rm_svgx_fpga_dev_board.pdf Reference Manual. Page 15 has the connections. Yes, the JTAG is a Virtual JTAG core. The FPGA and CPLD are connected using the FSM bus where the FPGA drives a Chip Select into the CPLD. A service request has been filed... but you how long that can take sometimes. You are correct, if I HAVE to, I can reverse engineer the whole programming sequence... Thanks Paul
