8 years agoStratix V GX dev kit does not work
Hi, After i flashed my device. No LED on the board is turned on and the fan runs will full speed. Is the board damaged? thanx
8 years agoHi,
--- Quote Start --- The MAX ERROR LED in on after flashing the factory Max V.POF file. --- Quote End --- That means FPGA configuration from Flash has failed so try to restore factory setting again refer previous post. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation)
