8 years agoStratix V GX dev kit does not work
Hi, After i flashed my device. No LED on the board is turned on and the fan runs will full speed. Is the board damaged? thanx
8 years ago --- Quote Start --- Hi, You can check the “Restoring the Flash Device to the Factory Settings” & then try again for “A. Programming the Flash Memory Device”. Have you faced any issue /Error while programming the Flash memory? Refer the “6. Board Test System”, https://www.altera.com/en_us/pdfs/literature/ug/ug_svgx_fpga_dev_kit.pdf Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation) --- Quote End --- The MAX ERROR LED in on after flashing the factory Max V.POF file. Regards,
