13 years agoStratix V DSP Kit Transcievers
Hi, I was looking at the schematic and the reference manual for the Stratix V DSP development kit http://www.altera.com/products/devkits/altera/kit-stratix-v-dsp.html The transceivers...
13 years ago --- Quote Start --- Data from a DE3 board via 8 LVDS channels to a Stratix V board via 8 transceivers. --- Quote End --- Why use the Stratix V board transceivers? The HSMC connector has LVDS too. Why not just connect LVDS to LVDS? --- Quote Start --- A tricky mess indeed. And of-course. As fast as possible which is around 1.6Gbps (so technically 1.28Gbps max actual throughput if 8/10b encoding) --- Quote End --- If you have to use the transceivers, and you plan on 8/10B encoding, then you should have no trouble configuring the Stratix V transceivers to receive and automatically align the data streams based on the 8/10B encoding. Cheers, Dave
