12 years agoStratix V Development board with QSFP ports
Hi, We have just bought a Bittware S5-PCIe-HQ development board which has a Stratix V FPGA. On the board are 2 QSFP+ ports. We wish to use these ports to transmit and receive data to and f...
12 years agoHi Dave,
I've been going through that tutorial and it helps alot. The tutorial supplied test-bench on p.28 (Avalon-MM Master BFM) does not work however. When I try to compile using "vlog -sv $TUTORIAL/hdl/qsys_system/test/qsys_system_bfm_master_tb.sv -L qsys_system_bfm_master" , I receive errors saying that could not find the package verbosity_pkg and avalon_mm_pkg. The test-bench JTAG-to-Avalon-MM Master on P.29 works tho. On p.31 under Synthesis and Simulation scripts it says to start Quartus and change to the Qsys BeMicro-SDK project and then use commands like "tcl> set TUTORIAL c:/temp/altera_jtag_to_avalon_mm_tutorial". How exactly do I do that in Quartus. Are those tcl commands? I am having problems also understanding how to implement the host-to-FPGA communication from p.33. There doesn't seem to be a step-by-step guide on how it is done. Thanks again for your help, Paul
