12 years agoStratix V Development board with QSFP ports
Hi, We have just bought a Bittware S5-PCIe-HQ development board which has a Stratix V FPGA. On the board are 2 QSFP+ ports. We wish to use these ports to transmit and receive data to and f...
12 years agoHi Paul,
--- Quote Start --- I don't know how to run a Modelsim simulation with an Avalon-MM master BFM but would like to know. --- Quote End --- Go through this tutorial; http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial This was written for an older version of Quartus, but the same general procedure works. Its written in SystemVerilog, since at the time, the Altera Verification IP Suite did not have good VHDL support. There is better support for VHDL now, however, I haven't used it, since simulation in SystemVerilog is ok with me (even though my synthesis code is in VHDL). --- Quote Start --- If I use a QSFP+ loopback, do I need to link a cable between the two ports or can do it without? --- Quote End --- There's several loopback options; 1. A physical loopback connector that connects the TX and RX pins in the QSFP+ connector http://www.elpeus.com/categories/qsfp-cables/qsfp-loopback-adapters.html 2. Internal loopback at the transmitter (nothing needed on the QSFP+ connector) 3. Internal loopback at the receiver (needs a QSFP+ cable between the transmitter and receiver) Cheers, Dave
