15 years agoStratix IV GX Pin Assignment
Hi, I'm working on the Stratix IV GX 230 board and I'm trying to use the Triple Speed Ethernet in RGMII mode with MDIO. I did everything well untill the moment I needed the PIN in order to co...
15 years agoI think that the PHY isn't responding since I don't get any real value on the Signaltap. So do I have to change anything with the MDIO or MDC or should I focus on the initialization software? (I tried to debug the software but it seems that the PHY won't answer)
There are reference design with ethernet interface on it that I've tried and it actually worked on the board, I guess it's just me who can't make it work with my project even though I do exactly the same thing as what is indicated in the reference design. In the other end of the cable, I have a computer that doesn't get any data when I have a WireShark active. I guess that's because my PHY isn't working yet. I guess my TSE work since my MAC is detected when I use the Simple_socket_server. It's just the MDIO that can't establish the correct configuration with the PHY in the SSS software or maybe that my MDIO bus isn't synthetized as a tristated bus maybe? Thank you for all your help Daixiwen.
