15 years agoStratix IV GX Pin Assignment
Hi, I'm working on the Stratix IV GX 230 board and I'm trying to use the Triple Speed Ethernet in RGMII mode with MDIO. I did everything well untill the moment I needed the PIN in order to co...
15 years ago0xFFFF means either that the PHY isn't answering or that the TSE doesn't get it.
You should have a different set of values on one of the PHY addresses. Is there any reference with an Ethernet interface delivered with the kit? Is the PHY working? I mean at the other end of the Ethernet cable, does the device you connect say that the link is active?
