15 years agoStratix IV GX Pin Assignment
Hi, I'm working on the Stratix IV GX 230 board and I'm trying to use the Triple Speed Ethernet in RGMII mode with MDIO. I did everything well untill the moment I needed the PIN in order to co...
15 years agoThanks for your help Daixiwen, I have already changed the buffer to what you said (because it had a strange behavior before) and my mdio_oen goes 0 when he wants the PHY's answer and 1 otherwise.
I can also see some toggling on the mdio_out pin which I believe is reassuring.. I'm compiling the project and I'll see if my PHY will finally work after that.
