15 years agoStratix IV GX Pin Assignment
Hi, I'm working on the Stratix IV GX 230 board and I'm trying to use the Triple Speed Ethernet in RGMII mode with MDIO. I did everything well untill the moment I needed the PIN in order to co...
15 years agoFrom what I see you can only use the Marvel PHY on this board in SGMII mode and not RGMII.
As for the MDIO pins, connect mdc to ENET_MDC and make a small tristate output for ENET_MDIO: when mdio_oen is 0 it should be an output with the value mdio_out, and when mdio_oen is 1 it should be an input, and the value fed to mdio_in.
