14 years agoStratix IV GX Development Kit - QDRII UniPHY Pinning
I'm using the Stratix IV GX Development Kit to evaluate QDRII(+)-SRAM. I've configured the QDRII+-MegaCore for that Stratix IV FPGA without any problems. The generated code was synthesized b...
14 years ago --- Quote Start --- Any suggestions? --- Quote End --- I haven't tested the QDRII+, however, I do have the following two options in my Tcl pin assignments script.
# Clock
if {0} {
set pin(qdr_top0_k) {PIN = P23, IOSTD = "DIFFERENTIAL 1.5-V HSTL CLASS I", SLEW = 3, TERMOUT = "SERIES 50 OHM WITH CALIBRATION"}
set pin(qdr_top0_k(n)) {PIN = N23}
} else {
set pin(qdr_top0_k) {PIN = P23, IOSTD = "1.5-V HSTL CLASS I", SLEW = 3, TERMOUT = "SERIES 50 OHM WITH CALIBRATION"}
set pin(qdr_top0_kN) {PIN = N23, IOSTD = "1.5-V HSTL CLASS I", SLEW = 3, TERMOUT = "SERIES 50 OHM WITH CALIBRATION"}
Try the second option. The PIN, IOSTD, SLEW, and TERMOUT settings get translated to
IOSTD {set_instance_assignment -name IO_STANDARD $val -to $port}
PIN {set_location_assignment -to $port "Pin_$val"}
SLEW {set_instance_assignment -name SLEW_RATE $val -to $port}
TERMOUT {set_instance_assignment -name OUTPUT_TERMINATION $val -to $port}
later on in the Tcl script. You can just use the set_instance_assignment versions directly. Cheers, Dave
