14 years agostratix iv gx dev.kit related issue
Hello all, when i power on the board , and try to communicate the kit through board test system .exe, powermonitor.exe and clockcontrol.exe the following error is encountered Connecting ...
14 years agofew things to check.
You may need to have exact same version of Quartus to the Board test system. If the BTS is 10.0, then you need to have Quartus 10.0. Second, you need to start 32bit version of Quartus to set up all the environment variables. Running 64bit won't over write correctly.
