13 years agoStratix IV 530 Dev. PCB factory_recovery mismatch
I inherited this Stratix IV 530 Dev. board which I can not program the CFI FLASH. I am following the guide but there is a mismatch somewhere. When I try to restore the factory recovery setting of the...
13 years ago --- Quote Start --- Thanks Dave. I also found the proper installation for my dev. board by going to all the way back to: ftp://ftp.altera.com/outgoing/devkit/91/stratixive_4se530es_fpga_v9.1.0.exe --- Quote End --- You have a kit with an E-series device? So you don't have a GX kit then (which has transceivers)? --- Quote Start --- and downloading the factory recovery files which I installed with ./restore.sh Once that was done I was able to install the userfile_hw.flash according to the user guide. --- Quote End --- Excellent! --- Quote Start --- Interestingly, in this version of the instructions, the --offset=0x0 but when programming (as you explained) the --base=0x0800_0000. --- Quote End --- The readme.txt file in the couple of kits I looked at indicated that the User Manual instructions had some errata. Check the readme.txt in your install area, perhaps it has a similar comment. Cheers, Dave
