13 years agoStratix IV 530 Dev. PCB factory_recovery mismatch
I inherited this Stratix IV 530 Dev. board which I can not program the CFI FLASH. I am following the guide but there is a mismatch somewhere. When I try to restore the factory recovery setting of the...
13 years ago --- Quote Start --- As far as I can tell there is only one (DK-DEV-4SGX530N) --- Quote End --- There are other boards from other manufacturers, eg., the Terasic DE4. I have this board, but in the 230K version. I've never bothered to use the factory files. What is it you want to get from the factory files? For example, if you want to know that you have a sane setup, I could send you a basic blinky LEDs file. It would be for the 230K design. But if you look at the pin assignments file I send you, you can check whether the assignments are the same on the 530K, or if you are worried about damaging the board, I can take a look tomorrow. If you really want to get the factory recovery files to work, I can try the 230K versions. Cheers, Dave
