17 years agoStratix III Dev kit ethernet problem
I am using the Stratix III dev kit: http://www.altera.com/products/devkits/altera/kit-siii-host.html and I have programmed the board with the correct NIOS II standard design. I am able to run al...
13 years agoHi, I need some support with this stratixIII_3sl150_dev_TSE_SGMII_v1.zip project which naceradsky uploaded here.
The connection seems to work fine, but I need to chenge the IP and Gateway data on the project, not on my computer as the documentation says. The problem is that I can't build the executable. I'm working with the NIOS II Eclipse IDE, but the makefile seems not to work with it. I wondered that the makefile is made to work with cygwin or MinGW (which I'm using right now), but I can't compile it because some problems are appearing. Does anyone know how to compile it? Or maybe does someone know the creator of the project and the contact to ask him? Thanks a lot.
