13 years agoStratix II GX limited sof file is not working
Hi, I am doing a project that uses Stratix II GX, currently, I can use the pof file from the example to run the hardware. The pof is loaded to the EPM570 device, I used windriver to test the hardw...
13 years agoWhen you upload a time limited .sof file, Quartus will then open a window saying that it is running in evaluation mode. Do you close this window? If yes, the design in the FPGA will stop working.
