13 years agoStratix II ES180 board, help me with DAC output
Hi all, I am in trouble with ADC module. I try to code a very simple code: module dac_test( input clk, output [13:0] dac ); assign dac = 14'b11110001010110; endmodule...
13 years agoDear Daixiwen
I found the problems...I dont know... the problem is...no problem. I did simple code... just output 14bit of 0 and 14bit of 1 following the frequency of input clock. the signal output in the stratix II board is changed with the frequency of input sequence. However, in the Stratix I (I test the code in two kinds of Stratix board), I can easily observe the output signal on oscilloscope in the same condition. But in the Stratix II board, I cant see any signal like in the stratix I board... Anyway, I knew what I am wrong. I learned a lot from forum and from you. thank you a gain
